Cisco SD-WAN routers use OMP for routing information on the overlay network. Within a site, sometimes you need an IGP like OSPF or perhaps BGP.
This lesson will explain how to configure BGP between a Cisco IOS device and a Cisco SD-WAN vEdge router. We’ll use feature and device templates to accomplish this.
Nothing fancy. We only have our vEdge1 router and SW1. I pre-configured SW1 with BGP. I’m using Cisco SD-WAN version 19.3.0.
vEdge1
system
host-name vEdge1
system-ip 172.16.1.1
site-id 2
sp-organization-name nwl-lab-sdwan
vbond 10.1.0.2
omp
no shutdown
graceful-restart
advertise connected
advertise static
vpn 0
interface ge0/0
ip address 10.65.91.1/24
tunnel-interface
encapsulation ipsec
color biz-internet
allow-service all
no shutdown
interface ge0/1
ip address 10.65.92.1/24
tunnel-interface
encapsulation ipsec
color public-internet
allow-service all
no shutdown
vpn 10
interface ge0/3
ip address 10.2.1.1/24
no shutdown
omp
advertise connected
vpn 512
interface eth0
shutdown
SW1
hostname SW1
ip cef
ip address 11.11.11.11 255.255.255.255
interface GigabitEthernet0/0
no switchport
ip address 10.2.1.101 255.255.255.0
router bgp 1
bgp log-neighbor-changes
network 11.11.11.11 mask 255.255.255.255
neighbor 10.2.1.1 remote-as 1
Let’s configure the vEdge1 router.
Feature Template: BGP
Go to Configuration > Templates > Feature and click on Add Template:
Specify a name:
Scroll down to NEIGHBOR and click on New Neighbor:
Fill in the Address and click on Add:
Our neighbor now shows up in the overview:
All the other settings are OK. Scroll down and click on Save.
Device Template
Go to Configuration > Templates > Device and edit the device template, which is attached to vEdge1:
Scroll down to Service VPN and select BGP under the Additional VPN Templates:
VPN 10 & VPN 20 are configured as services VPN.
Configured OSPF inside the VPN 10 for network 10.1.1.0/24
Configured BGP inside the VPN 20 for network 10.11.1.0/24
Redistributed BGP to OMP & OMP to BFP
I can see an outside router in the VPN 10 show IP route vpn 10 but I can’t see any outside router in VPN 20 show IP route vpn 20
Attaching the configuration file here
vEdge-DELHI-2# show ip routes vpn 10
... Continue reading in our forumCodes Proto-sub-type:
IA -> ospf-intra-area, IE -> ospf-inter-area,
E1 -> ospf-external1, E2 -> ospf-external2,
N1 -> ospf-nssa-external1, N2 ->
Yes,
But i can see VPN20 Routes to vSmart from Dilhi Edge Router
