Basic OSPF Configuration
ospf cost per interface
CCNA students need to understand how OSPF works but also how to configure it. If you have no idea what OSPF is or if you are a little fuzzy, I recommend you to read my Introduction to OSPF first before continuing. Having said that, let’s configure OSPF! This is the topology I will use:
ospf lab single area
This is the topology that we’ll use. All routers are in OSPF Area 0. Note that the link between R2 and R1 is an Ethernet (10Mbit) link. All other links are FastEthernet (100Mbit) interfaces.
We’ll start with the configuration between R2 and R3:
R2(config)#router ospf 1
R3(config)#router ospf 1
I need to use the router ospf command to get into the OSPF configuration. The number “1” is a process ID and you can choose any number you like. It doesn’t matter and if you want you can use a different number on each router.
The second step is to use the network command. It works similar to RIP but it is slightly different, let me break it down for you:
Just like RIP the network command does two things:
  • Advertise the networks that fall within this range in OSPF.
  • Activate OSPF on the interface(s) that fall within this range. This means that OSPF will send hello packets on the interface.
Behind 192.168.23.0 you can see it says 0.0.0.255. This is not a subnet mask but a wildcard mask. A wildcard mask is a reverse subnet mask. Let me give you an example:
Subnetmask
255
255
255
0
11111111
11111111
11111111
00000000
Wildcardmask
0
0
0
255
00000000
00000000
00000000
11111111
When I say reverse subnet mask I mean that the binary 1s and 0s of the wildcard mask are flipped compared to the subnet mask. A subnet mask of 255.255.255.0 is the same as wildcard mask 0.0.0.255. Don’t worry about this too much for now as I’ll explain wildcard masks to you when we talk about access-lists!
OSPF uses areas so you need to specify the area:
area 0
In our example we have configured single area OSPF. All routers belong to area 0.
After typing in my network command you’ll see this message in the console:
R3# %OSPF-5-ADJCHG: Process 1, Nbr 192.168.23.2 on FastEthernet0/0 from LOADING to FULL, Loading Done
R2# %OSPF-5-ADJCHG: Process 1, Nbr 192.168.23.3 on FastEthernet1/0 from LOADING to FULL, Loading Done
Great! It seems that R3 and R2 have become neighbors. There’s another command we can use to verify that we have become neighbors:
R3#show ip ospf neighbor
192.168.23.2 1 FULL/BDR 00:00:36 192.168.23.2 FastEthernet0/0
R2#show ip ospf neighbor
192.168.23.3 1 FULL/DR 00:00:32 192.168.23.3 FastEthernet1/0
Show ip ospf neighbor is a great command to see if your router has OSPF neighbors. When the state is full you know that the routers have successfully become neighbors.
Each OSPF router has a router ID and we check it with the show ip protocols command:
R2#show ip protocols
Routing Protocol is "ospf 1"
Router ID 192.168.23.2
R3#show ip protocols
Router ID 192.168.23.3
Above you see the router ID of R2 and R3. They used their highest active IP address as the router ID. Let’s create a loopback on R2 to see if the router ID changes…
R2(config)#interface loopback 0
R2(config-if)#ip address 2.2.2.2 255.255.255.0
This is how you create a loopback interface. You can pick any number that you like it really doesn’t matter.
The router ID still the same. We need to reset the OSPF process before the change will take effect, this is how you do it:
R2#clear ip ospf process
Reset ALL OSPF processes? [no]: yes
Use clear ip ospf process to reset OSPF. Let’s see if there is a difference:
Router ID 2.2.2.2
We can also change the router ID manually. Let me demonstrate this on R3:
Right now it’s 192.168.23.3…
R3(config-router)#router-id 3.3.3.3
Reload or use "clear ip ospf process" command, for this to take effect
R3#clear ip ospf process
The router is friendly enough to warn me to reload or clear the OSPF process. Let’s verify our configuration:
Router ID 3.3.3.3
As you can see above the router ID is now 3.3.3.3.
Changing the router ID isn’t something you would normally do. IP addresses on your router have to be unique so your OSPF router ID will also be unique. Understanding how OSPF selects a router ID is something you have to understand for the exam however.
Right now we have an OSPF neighbor adjacency between R2 and R3. Let’s configure our routers so that R2/R1 and R1/R3 also become OSPF neighbors:
R1(config)#router ospf 1
R1(config-router)#network 192.168.13.0 0.0.0.255 area 0
R3(config-router)#network 192.168.13.0 0.0.0.255 area 0
I’ll advertise all networks in OSPF. Before we check the routing table it’s a good idea to see if our routers have become OSPF neighbors:
192.168.13.1    1   FULL/BDR  00:00:31    192.168.12.1  Ethernet0/0
3.3.3.3         1   FULL/DR   00:00:38    192.168.23.3  FastEthernet1/0
R1#show ip ospf neighbor
3.3.3.3         1   FULL/BDR  00:00:33    192.168.13.3  FastEthernet1/0
2.2.2.2         1   FULL/DR   00:00:30    192.168.12.2  Ethernet0/0
192.168.13.1    1   FULL/DR   00:00:37    192.168.13.1    FastEthernet1/0
2.2.2.2         1   FULL/BDR  00:00:30    192.168.23.2    FastEthernet0/0
Excellent our routers have become OSPF neighbors and the state is full which means they are done exchanging information. Let’s check the routing tables:
R2#show ip route ospf
O    192.168.13.0/24 [110/2] via 192.168.23.3, 00:09:45, FastEthernet1/0
R2 has one entry, it’s for network 192.168.13.0 /24. What exactly do we see here?
If you like to keep on reading, Become a Member Now!
  • Full Access to our 804 Lessons. More Lessons Added Every Week!
408 Sign Ups in the last 30 days
satisfaction-guaranteed
  • No Questions Asked!
  1. Thank you very much Rene for your work. I appreciate much :wink:
  2. Very good lesson! Thanks for all your work!
  3. Very good lesson! Thanks for all your work!
  4. Hi Rene,
    When connecting 3 routers(a router triangle) to configure OSPF, will it make a difference if I created point-to-point serial connections as opposed to using the ethernet ports?
    Mo
  5. Hi Mo,
    There will be two differences:
    - The cost will be higher (that’s no problem) because the link is slower.
    - OSPF treats point-to-point links differently than multi-access links (Ethernet). One of the things is that it doesn’t elect a DR/BDR on point-to-point links.
101 more replies! Ask a question or join the discussion by visiting our Community Forum
