User Mode and Privileged Mode Security
In this lesson, we’ll take a look at how you can secure user mode and privileged (enable) mode. By default, there is no authentication required. If you connect a Cisco console cable to your switch or router, here’s what happens:
Switch con0 is now available
Press RETURN to get started.
Switch>
Once you press the enter button, we end up in user mode right away. There’s no password or anything. The same thing applies to the enable mode:
Switch>enable
Switch#
We have full access right away. This is something you might want to change, which is what I’ll explain in this lesson.
User Mode Security
Let’s start with user mode.
Simple Password
The most simple option to protect user mode is to add a password. Here’s how to do this:
Switch(config)#line console 0
First, we need to enter the console settings. Here’s where we have to add two commands:
Switch(config-line)#password cisco
Switch(config-line)#login
We configure a password (cisco) and use the login command to tell Cisco IOS to prompt for this password. Next time you open the console, this will happen:
User Access Verification
Password:
Switch>
The CLI will ask you for the password. At least we have some form of authentication but we can do better…
Username and Password
Instead of a single password, it’s also possible to use usernames and passwords instead. This is a better option if you have multiple people that need to access your router or switch. Here’s how to do this:
Switch(config-line)#login local
Switch(config-line)#exit
Switch(config)#username admin password cisco
Under the console settings, we use the login local command to tell the switch to refer to a local database of usernames and passwords for authentication. In the global config, we create a username “admin” with password “cisco”.
Next time you open the console, here’s what you see:
Username: admin
Password:
Switch>
The switch asks for our username and password.
Enable Mode Security
What about enable mode / privileged mode? We can also add a password there. You need to do this from the configuration mode:
Switch#configure terminal
Now we can set a password for enable mode:
Switch(config)#enable password cisco
Let’s see if our password “cisco” works. Let’s get out of enable mode:
Switch#disable
And jump right back in:
Switch>enable
Password:
The switch now asks for the password.
Password Encryption
In the examples above, we used passwords but there is one problem…they all show up in clear text in our configuration. Take a look below:
Switch#show running-config | include password
username admin password 0 cisco
It’s all clear text. If someone steals one of your switches or routers, they will have your passwords. If you ever backup your configuration and forget to remove the passwords, same problem.
Cisco IOS has a command that lets you encrypt all clear text passwords in your configuration. Here’s how:
Switch(config)#service password-encryption
The service password-encryption command will encrypt every password that is plain text. Here you can see the result:
enable password 7 13061E010803
username admin password 7 110A1016141D
Now you might get a warm fuzzy feeling that everything is encrypted but in reality, this is a very poor (broken) encryption algorithm. There are websites that let you decrypt these encrypted strings on the fly. If you want to try this, here’s one of those websites.
We need something stronger…
Secret
Cisco IOS supports something called a secret as an alternative to the password. Let’s try this for the enable mode:
Switch(config)#enable secret ?
  0      Specifies an UNENCRYPTED password will follow
  5      Specifies a MD5 HASHED secret will follow
  8      Specifies a PBKDF2 HASHED secret will follow
  9      Specifies a SCRYPT HASHED secret will follow
  LINE   The UNENCRYPTED (cleartext) 'enable' secret
  level  Set exec level password
Above you can see this switch supports MD5, PBKDF2 and SCRYPT hashes. Older IOS devices only support MD5 authentication.
Let’s give this a try:
Switch(config)#enable secret cisco
Our secret will be “cisco”. Let’s see what we find in the configuration:
Switch#show running-config | include secret
enable secret 5 $1$CANW$U9Y8O6KeFhrFR4l1Qo07h/
You now find an MD5 hash in the configuration. The “5” that you see behind “enable secret” is the algorithm that we use, 5 means MD5.
MD5 is not considered secure nowadays. It’s very easy to brute force simple passwords. For example, try this website for the MD5 hash that was created for my secret “cisco”. It will only take a few seconds to recover.
Let’s try one of the other algorithms that are considered secure nowadays. Here’s how you can select the algorithm for the enable mode:
Switch(config)#enable algorithm-type ?
  md5     Encode the password using the MD5 algorithm
  scrypt  Encode the password using the SCRYPT hashing algorithm
  sha256  Encode the password using the PBKDF2 hashing algorithm
Let’s try the PBKDF2 (SHA256) hashing algorithm:
Switch(config)#enable algorithm-type sha256 secret cisco
When we look at our configuration, we’ll see the new hash:
enable secret 8 $8$dvX/fx/FJ0Snk2$HhqrOUaEtBgk4zJvG2IQuAJNUicZmmELelC/L6.Fcl2
The “8” behind “enable secret” refers to the PBKDF2 hashing algorithm that we used.
In the example above I changed the hashing algorithm for the enable mode but we can also do this for usernames. Here’s an example:
Switch(config)#username rene algorithm-type sha256 secret cisco
My username now uses SHA256 as well for password “cisco”. Here’s what it looks like:
Switch#show running-config | include rene
username rene secret 8 $8$dyzsAmZjA3w.aY$YBZn8LBI6CK04ij5ZmqQ/88OrFdc3jzGb6v7SSQI0cw
Make sure you use strong passwords. No matter what hashing algorithm you use, weak passwords like “cisco” are easily recovered.
External Authentication Servers
Configuring usernames and secrets on your Cisco IOS devices is a good practice but one issue we have is scalability. If you have a network with multiple devices, you will have to configure your usernames/secrets on all devices. If you change your password, you have to do it on all devices.
  1. Avatar for rosamariasanchez080 rosamariasanchez080 says:
    HI Rene,
    In most of the switches 2960X I dont have the option of login lor login local.
    It only appears the option login authentication default that requires a list for login
    Hello Helen,
    It seems they changed this a bit on IOS 15.x. You can find an example here:
    https://www.cisco.com/c/en/us/...l?bookSearch=true
    Once aaa new-model is enabled, you can use the login command:
    Switch(config)# aaa new-model
    Switch(config)# line vty 0 15
    Switch(config-line)# login local
    Switch(config-line)# exit
    Try this on a test switch first, usually when you mess around with AAA it’s easy to lock yourself out :sweat_smile:
  3. Avatar for louis1 louis1 says:
    Hey everyone,
    I’ve been looking into passwords/secrets on Cisco devices, and am a bit confused regarding how to configure the best practice (most secure) password type.
    I’ve successfully configured type 7 passwords on devices, enabled password encryption (so they don’t show as plain text in the config) then have been able to SSH to the device using those credentials.
    However I’ve read that type 7 passwords are not secure, and using an online crack tool was easily able to crack my encrypted type 7 passwords. When I search online regarding this everyone says
    Hello Louis
    Currently, the most secure method for encrypting passwords in your Cisco IOS devices is using a type 8 or type 9 encryption which use PBKDF2-SHA-256 and scrypt respectively. These are currently the most secure types, but must be supported by the IOS you are using. For more info about the various types, take a look at the following post on Cisco’s learning network:
    https://learningnetwork.cisco....rs-password-types
    As for how to use one of these for SSH, I was able to create a user with a secret using type 5 like so:
    R2(config)#username
  5. Avatar for louis1 louis1 says:
    Hey Laz,
    Thanks for the response!
    I tried again configuring the secret 5 with a username using your instructions, and I can SSH successfully from another device now – not sure what went wrong last time.
    I tried the stronger encryption method mentioned by Rene in the article, however the commands don’t exist on the router I’m using, so I assume it requires a newer IOS version.
    According to the Cisco document you linked, the secret 5 can be cracked but would take a long time – therefore I assume it’s “good enough” to use in a production environment. Would
5 more replies! Ask a question or join the discussion by visiting our Community Forum
