TCP Header
TCP (Transmission Control Protocol) is a reliable transport protocol as it establishes a connection before sending any data and everything that it sends is acknowledged by the receiver. In this lesson we will take a closer look at the TCP header and its different fields. Here’s what it looks like:
TCP header fields: source port, destination port, sequence number, acknowledgment number, data offset (DO), reserved (RSV), flags, window, checksum, urgent pointer and options
Let’s walk through all these fields:
  • Source port: this is a 16 bit field that specifies the port number of the sender.
  • Destination port: this is a 16 bit field that specifies the port number of the receiver.
  • Sequence number: the sequence number is a 32 bit field that identifies the first data byte in this segment. TCP numbers every byte that it sends, so the receiver knows the order of the data and which bytes it has received. When you establish a new TCP connection (3 way handshake) then the initial sequence number is a random 32 bit value. The receiver will use this sequence number and sends back an acknowledgment. Protocol analyzers like wireshark will often use a relative sequence number of 0 since it’s easier to read than some high random number.
  • Acknowledgment number: this 32 bit field is used by the receiver to tell the sender which byte it expects next. This value will be the received sequence number plus the number of data bytes in the segment. The SYN and FIN flags count as one byte, so the acknowledgment for a SYN is the sequence number incremented by 1.
  • DO: this is the 4 bit data offset field, also known as the header length. It indicates the length of the TCP header so that we know where the actual data begins.
  • RSV: these are 3 bits for the reserved field. They are unused and are always set to 0.
  • Flags: there are 9 bits for flags, we also call them control bits. We use them to establish connections, send data and terminate connections:
    • URG: urgent pointer. When this bit is set, the data should be treated as priority over other data.
    • ACK: used for the acknowledgment.
    • PSH: this is the push function. The sending application uses this to tell TCP that the data should be transmitted immediately and that we don’t want to wait to fill the entire TCP segment.
    • RST: this resets the connection, when you receive this you have to terminate the connection right away. This is only used when there are unrecoverable errors and it’s not a normal way to finish the TCP connection.
    • SYN: we use this for the initial three way handshake and it’s used to set the initial sequence number.
    • FIN: this finish bit is used to end the TCP connection. TCP is full duplex so both parties will have to use the FIN bit to end the connection. This is the normal method how we end an connection.
    • CWR: congestion window reduced. The sender uses this to tell the receiver that it has reduced its congestion window. This is used for ECN (Explicit Congestion Notification).
    • ECE: ECN-Echo. The receiver uses this to tell the sender that it received an IP packet with the CE (Congestion Experienced) codepoint.
    • AE: accurate ECN. This bit is used by AccECN (RFC 9768). It used to be the nonce sum (NS) bit, which is why Wireshark calls it “Nonce” in the capture below.
  • Window: the 16 bit window field specifies how many bytes the receiver is willing to receive. It is used for flow control, so the receiver can tell the sender how much data it is willing to accept. It does so by specifying the number of bytes beyond the sequence number in the acknowledgment field.
  • Checksum: 16 bits are used for a checksum to check if the TCP segment is OK or not. The checksum covers the TCP header, the data and a pseudo-header with the source and destination IP addresses.
  • Urgent pointer: these 16 bits are used when the URG bit has been set, the urgent pointer is used to indicate where the urgent data ends.
  • Options: this field is optional and can be anywhere between 0 and 320 bits.
To see these fields in action, it’s best to play around with wireshark. Here’s an example of the first part of the TCP three way handshake. I highlighted all the fields:
  1. Avatar for yassinow2008 yassinow2008 says:
    hi Rene,
    I have been trying to use the wireshark to see how this things are but I can’t get there. what can i do?
    Hi Yassin,
    What exactly is not working for you?
  3. Avatar for amrutapkhare amrutapkhare says:
    hi Rene,
    Can you please explain this sentence–Sequence number: the sequence number is a 32 bit field that indicates how much data is sent during the TCP session.
    Amruta,
    This has to do with how the sequence number is incremented during the TCP session. Let’s say Client A is requesting 900 Bytes of data from Server 1. Once Server 1 starts to send the actual data to Client A, the length of the payload of what is being sent directly influences the next sequence number.
    So, let’s say the current Sequence number is 1, and the Server sends Client A, 300 Bytes. This means the sequence number will now be 301 (the original sequence number plus the amount of data in the payload that was just sent). Now, let’s say, after
  5. Avatar for hussien.samer hussien.samer says:
    From what I learned that the maximum size of data that we can send it through one TCP connection = 2^36 = 68719476736 bytes ( Equivalent 68 gigabytes ) and the number 36 came from 32 the seq number filed size plus 4 the DO filed size, please correct me if I wrong.
    Best regard
    Hussein Samir
56 more replies! Ask a question or join the discussion by visiting our Community Forum
