Trunking on Cisco IOS Switch
Trunks are required to carry VLAN traffic from one switch to another. This lesson will demonstrate how to configure a trunk between Cisco Catalyst switches. Let me show you the topology that we’ll use:
two cisco switches
Above, you see a topology with a computer connected to each switch. We’ll put the computers in the same VLAN and create a trunk between the two switches.
Let’s start by creating a VLAN:
SW1(config)#vlan 50
SW1(config-vlan)#name Computers
SW1(config-vlan)#exit
SW2(config)#vlan 50
SW2(config-vlan)#name Computers
SW2(config-vlan)#exit
And let’s put the interfaces connected to the computers in the correct VLAN:
SW1(config)#interface fa0/1
SW1(config-if)#switchport access vlan 50
SW2(config)#interface fa0/2
SW2(config-if)#switchport access vlan 50
The next step is to create a trunk between the two switches. Technically the interfaces between the two switches can also be in access mode right now because I only have a single VLAN.
SW1(config)#interface fa0/14
SW1(config-if)#switchport mode trunk
Command rejected: An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
SW2(config)#interface fa0/14
SW2(config-if)#switchport mode trunk
I try to change the interface to trunk mode with the switchport mode trunk command. Depending on the switch model, you might see the same error as me. If we want to change the interface to trunk mode, we need to change the trunk encapsulation type. Let’s see what options we have:
SW1(config-if)#switchport trunk encapsulation ?
  dot1q      Interface uses only 802.1q trunking encapsulation when trunking
  isl        Interface uses only ISL trunking encapsulation when trunking
  negotiate  Device will negotiate trunking encapsulation with peer on interface
This is where you can choose between 802.1Q or ISL encapsulation. By default, our switch will negotiate about the trunk encapsulation type.
SW1(config-if)#switchport trunk encapsulation dot1q
SW2(config-if)#switchport trunk encapsulation dot1q
Let‟s change it to 802.1Q by using the switchport trunk encapsulation command.
SW1#show interfaces fa0/14 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Administrative Trunking Encapsulation: dot1q
SW2#show interfaces fa0/14 switchport
Switchport: Enabled
As you can see the trunk encapsulation is now 802.1Q.
Now I can successfully change the switchport mode to trunk.
Switchport: Enabled Administrative Mode: trunk Operational Mode: trunk
Operational Trunking Encapsulation: dot1q
We can confirm we have a trunk because the operational mode is “dot1q”.
Let’s try if H1 and H2 can reach each other:
Excellent! H1 and H2 can reach each other! Does this mean we are
done? Not quite yet…there is more I want to show to you:
SW2#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/3, Fa0/4, Fa0/5
                                                Fa0/6, Fa0/7, Fa0/8, Fa0/9
                                                Fa0/10, Fa0/11, Fa0/12, Fa0/13
                                                Fa0/15, Fa0/22, Fa0/23, Fa0/24
                                                Gi0/1, Gi0/2
50   Computers                        active    Fa0/2
First of all, if we use the show vlan command, we don’t see the Fa0/14 interface. This is completely normal because the show vlan command only shows interfaces in access mode and no trunk interfaces.
SW2#show interface fa0/14 trunk
Port        Mode             Encapsulation  Status        Native vlan
Fa0/14      on               802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/14      1-4094
Port        Vlans allowed and active in management domain
Fa0/14      1,50
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/14      50
The show interface trunk command is useful. You can see if an interface is in trunk mode, which trunk encapsulation protocol it uses (802.1Q or ISL), and what the native VLAN is. We can also see that VLANs 1 – 4094 are allowed on this trunk.
We can also see that only VLAN 1 (native VLAN) and VLAN 50 are currently active. Last but not least, you can see which VLANs are in the forwarding state for spanning tree.
I want to show you one more thing about access and trunk interfaces:
SW2#show interface fa0/2 switchport
Switchport: Enabled
An interface can be in access mode or in trunk mode. The interface above is connected to H2, and you can see that the operational mode is “static access,” which means it’s in access mode.
Switchport: Enabled
This is our trunk interface which is connected to SW1. You can see the operational mode is trunk mode.
SW2(config-if)#switchport mode ?
  access        Set trunking mode to ACCESS unconditionally
  dot1q-tunnel  set trunking mode to TUNNEL unconditionally
  dynamic       Set trunking mode to dynamically negotiate access or trunk
  private-vlan  Set private-vlan mode
  trunk         Set trunking mode to TRUNK unconditionally
If I go to the interface configuration to change the switchport mode, you can see I have more options than access or trunk mode. There is also a dynamic method. Don’t worry about the other options for now.
SW2(config-if)#switchport mode dynamic ?
  auto       Set trunking mode dynamic negotiation parameter to AUTO
  desirable  Set trunking mode dynamic negotiation parameter to DESIRABLE
We can choose between dynamic auto and dynamic desirable. Our switch will automatically determine if the interface should become access or trunk port. So what’s the difference between dynamic auto and dynamic desirable? Let’s find out!
sw1-sw2
I’m going to play with the switchport mode on SW1 and SW2, and we’ll see the result.
668 Sign Ups in the last 30 days
satisfaction-guaranteed
100% Satisfaction Guaranteed!
No Questions Asked!
Tags: ,
  1. You have a very unique way of explaining, Clear and direct to the point. I am very grateful.
  2. I really appreciate your efforts :slight_smile:
  3. Hi ,
    Im following you LAB but i would like to know how to change the Operational Mode
    status .
    Every times i would like to change it , it doesn’t work .
    #sh int Fa0/21 switchport
    Switchport: Enabled
    Operational Mode: down <—
    Negotiation of Trunking: Off
    Access Mode VLAN: 50 (TesteIMO(NOTOUCH))
    Voice VLAN: none
    Thanks for your help .
  4. Can u check whether u made it no shut?
  5. Please clarify how to interpret the table you listed in the page below with different modes
96 more replies! Ask a question or join the discussion by visiting our Community Forum
