DMVPN Phase 3 RIP Routing
In this lesson we’ll take a look how to configure RIP on a DMVPN phase 3 network. If you are unsure what the differences between the different DMVPN phases are then you might want to start with my introduction to DMVPN first.
We will use the DMVPN phase 3 basic configuration for this example. Here’s the topology we will use:
We have a hub router and two spoke routers. Here’s the DMVPN phase 3 configuration:
Hub(config)#interface Tunnel0
Spoke2(config-if)#ip nhrp shortcut
Let’s make sure the hub has two NHRP registrations:
Hub#show dmvpn
        C - CTS Capable
Type:Hub, NHRP Peers:2,
     1 192.168.123.2      172.16.123.2    UP 00:00:04     D
     1 192.168.123.3      172.16.123.3    UP 00:00:03     D
So far so good, can we ping the spoke routers?
Hub#ping 172.16.123.2
Hub#ping 172.16.123.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 7/7/8 ms
Our pings are working, time to configure RIP…
RIP
Unlike DMVPN phase 2, our spoke routers don’t need specific entries in their routing tables. The only thing they’ll need is a summary that covers the networks behind all spoke routers or a default route. I’ll configure the hub router so that it will only advertise a default route to the spoke routers:
Hub(config)#ip prefix-list DEFAULT_ROUTE permit 0.0.0.0/0
Hub(config)#router rip
Hub(config-router)#version 2
Hub(config-router)#network 172.16.0.0
Hub(config-router)#default-information originate
Hub(config-router)#distribute-list prefix DEFAULT_ROUTE out Tunnel 0
We will configure the spoke routers so that they advertise everything to the hub:
Spoke1(config)#router rip
Spoke1(config-router)#network 172.16.0.0
Spoke2(config)#router rip
Spoke2(config-router)#network 172.16.0.0
Spoke2(config-router)#network 3.0.0.0
That should do it, let’s check the routing tables:
Hub#show ip route
R        2.2.2.2 [120/1] via 172.16.123.2, 00:00:16, Tunnel0
R        3.3.3.3 [120/1] via 172.16.123.3, 00:00:24, Tunnel0
Spoke1#show ip route rip
R*    0.0.0.0/0 [120/1] via 172.16.123.1, 00:00:28, Tunnel0
Spoke2#show ip route rip
R*    0.0.0.0/0 [120/1] via 172.16.123.1, 00:00:02, Tunnel0
Our hub has learned the two networks on the loopback interfaces of our spoke routers. The spokes only have a default route.
In my example I am able to advertise a default route since the underlay network is directly connected. In a real world scenario, your spoke routers probably already use a default route towards the ISP. In that case, you should advertise a summary instead of a default route.
Before we test spoke-to-spoke connectivity, let me show you the NHRP cache on the two spoke routers:
Spoke1#show dmvpn | begin Peer
Type:Spoke, NHRP Peers:1,
     1 192.168.123.1      172.16.123.1    UP 00:22:10     S
Spoke2#show dmvpn | begin Peer
     1 192.168.123.1      172.16.123.1    UP 00:22:32     S
Right now the two spoke routers only have an entry for the hub router, this will change in a minute. Before I test connectivity between spoke1 and spoke2, let’s enable a debug:
Hub, Spoke1 & Spoke2#debug nhrp
NHRP protocol debugging is on
Now let’s send a ping:
Spoke1#ping 3.3.3.3 source loopback0
When both spoke routers don’t know about each others NBMA addresses then this will produce a lot of debug information. In the debug below I filtered some of the lines so that you only see how spoke1 learns the NBMA address of spoke2:
Hub#
NHRP: NHRP successfully resolved 172.16.123.2 to NBMA 192.168.123.2
NHRP: Attempting to Redirect, remote_nbma: 192.168.123.2
NHRP: inserting (192.168.123.2/3.3.3.3) in redirect table
NHRP: Pre-setting NBMA address in NHRP Traffic Indication to: 192.168.123.2
NHRP: Attempting to send packet via DEST 2.2.2.2
NHRP: Switching NHRP Packet using pre-set NBMA: 192.168.123.2
NHRP: Encapsulation succeeded.  Tunnel IP addr 192.168.123.2
NHRP: Send Traffic Indication via Tunnel0 vrf 0, packet size: 97
      src: 172.16.123.1, dst: 2.2.2.2
NHRP: 121 bytes out Tunnel0
NHRP: Receive Resolution Request via Tunnel0 vrf 0, packet size: 85
NHRP: netid_in = 1, to_us = 0
NHRP: nhrp_rtlookup yielded interface Tunnel0, prefixlen 32
NHRP: netid_out 1, netid_in 1
NHRP: nhrp_cache_lookup_comp returned 0x0
NHRP: Attempting to forward to destination: 3.3.3.3
NHRP: Forwarding: NHRP SAS picked source: 172.16.123.1 for destination: 3.3.3.3
NHRP: Attempting to send packet via DEST 3.3.3.3
NHRP: NHRP successfully resolved 172.16.123.3 to NBMA 192.168.123.3
NHRP: Encapsulation succeeded.  Tunnel IP addr 192.168.123.3
NHRP: Forwarding Resolution Request via Tunnel0 vrf 0, packet size: 105
      src: 172.16.123.1, dst: 3.3.3.3
NHRP: 129 bytes out Tunnel0
Above you can see that the receives the packet with destination 2.2.2.2 from spoke1. The hub will then send a NHRP traffic indication to the spoke1 router. This will trigger a NHRP resolution request on spoke1 which is received by the hub.
The resolution request is then forwarded by the hub to spoke2.
Here’s what it looks like on spoke1:
  • Unlock Access to 807 lessons by becoming a member.
🔥 2544 people registered in the last 30 days
Tags: , ,
  1. It would have been nice if you had used loopback address of 1.1.1.1 for spoke 1 and loop address of 2.2.2.2 for spoke 2 and then loop address of 3.3.3.3 for hub in your examples. Would have been a lot easier to understand the debugs and illustrations that way.
  2. Can I ask why did you use default information originate and the distribute list with a default route in? What was the purpose of the DL?
  3. Hello Chris,
    With DMVPN phase 3, the spoke routers don’t need a specific route…only a default route.
    I used the distribute-list to ensure the spoke routers only receive that default route, nothing else.
  4. Hi Laz,
    • Can i know why don’t we know specific route entry unlike phase 2?
    *Again confusion with new term NHRP indication and in what against hub will send nhrp indication as well as we haven’t use nhrp redirect concept anywhere?
    Could you explore what spoke 1 will send and to whom talk to with so hub will send nhrp indication and what is this nhrp indication, how it will processed?
  5. Hello Pradyumna
    This is explained in the Phase 3 section of the following lesson:
    https://networklessons.com/cisco/ccie-routing-switching/introduction-to-dmvpn#Phase_3
    A an NHRP traffic indication is simply an NHRP redirect. The full te
