DMVPN Phase 2 RIP Routing
In the previous lesson about DMVPN I explained how to create a basic DMVPN phase 2 configuration, we’ll use this configuration and configure RIP on top of it. Here’s the topology we will use:
DMVPN Hub, Spoke1 and Spoke2 with tunnel 172.16.123.0/24, Gi0/1 192.168.123.x and loopbacks
We have one hub router and two spoke routers, each router has a loopback interface which we will advertise in RIP.
Tunnel Interfaces
Here’s the tunnel interface of the hub router:
Hub(config)#interface Tunnel0
Hub(config-if)#end
And here are the spoke routers:
Let’s do a quick check to verify if the tunnels are working:
Hub#show dmvpn
        C - CTS Capable
Type:Hub, NHRP Peers:2,
     1 192.168.123.2      172.16.123.2    UP 00:09:48     D
     1 192.168.123.3      172.16.123.3    UP 00:09:56     D
We see two NHRP registrations on the hub, let’s try a ping to the two spoke routers:
Hub#ping 172.16.123.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/7/11 ms
Hub#ping 172.16.123.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 6/7/10 ms
We have connectivity, now we can try RIP!
RIP
We’ll start with a basic configuration of RIP, we use version 2 and advertise all networks:
Hub(config)#router rip
Hub(config-router)#version 2
Hub(config-router)#network 1.0.0.0
Hub(config-router)#network 172.16.0.0
Spoke1(config)#router rip
Spoke1(config-router)#network 172.16.0.0
Spoke2(config)#router rip
Spoke2(config-router)#network 3.0.0.0
Spoke2(config-router)#network 172.16.0.0
Now let’s see what we find in our routing tables:
Hub#show ip route rip
R        2.2.2.2 [120/1] via 172.16.123.2, 00:00:07, Tunnel0
R        3.3.3.3 [120/1] via 172.16.123.3, 00:00:06, Tunnel0
The hub has two entries in its routing table, these are the loopback interfaces of the spoke routers. The next hop addresses are the IP addresses on the tunnel interfaces. When we want to resolve them, we’ll use the information from NHRP:
Hub#show dmvpn | begin Hub
     1 192.168.123.2      172.16.123.2    UP 00:29:29     D
     1 192.168.123.3      172.16.123.3    UP 00:07:24     D
What about the spoke routers? Let’s check their routing tables:
Spoke1#show ip route rip
R        1.1.1.1 [120/1] via 172.16.123.1, 00:00:17, Tunnel0
Spoke2#show ip route rip
R        1.1.1.1 [120/1] via 172.16.123.1, 00:00:08, Tunnel0
The spoke routers only have an entry for the loopback interface of the hub router. The problem here is that by default, split horizon is enabled. If we want direct spoke-to-spoke communication then our spoke routers need to learn each others networks. Let’s disable split horizon on the hub:
Hub(config)#interface Tunnel 0
Hub(config-if)#no ip split-horizon
Let’s see if this made any difference:
R        1.1.1.1 [120/1] via 172.16.123.1, 00:00:10, Tunnel0
R        3.3.3.3 [120/2] via 172.16.123.3, 00:00:10, Tunnel0
R        1.1.1.1 [120/1] via 172.16.123.1, 00:00:01, Tunnel0
R        2.2.2.2 [120/2] via 172.16.123.2, 00:00:01, Tunnel0
Great! The spoke routers learned each others loopback interfaces. Also take a good look at the next hop IP addresses, these are the tunnel addresses of the spoke routers. This should allow the spoke routers to reach each other directly without going through the hub.
Before we test this, let’s enable a debug on all routers so that you can see what is going on behind the scenes:
Hub, Spoke1 & Spoke2
#debug nhrp
NHRP protocol debugging is on
Now let’s try a traceroute from spoke1 to spoke2:
Tracing the route to 3.3.3.3
  1 172.16.123.3 6 msec 8 msec *
As you can see above, our traffic goes from spoke1 to spoke2 directly! Our traffic doesn’t go through the hub router like in DMVPN phase 1.
In our example, both spoke routers don’t know each others NBMA address so they will start sending NHRP resolution requests to the hub router. In the debug below I will only show you the process of spoke1 trying to figure out the NBMA address of spoke2:
Hub#
NHRP: NHRP successfully resolved 172.16.123.2 to NBMA 192.168.123.2
NHRP: Receive Resolution Request via Tunnel0 vrf 0, packet size: 85
NHRP: netid_in = 1, to_us = 0
NHRP: nhrp_rtlookup yielded interface Tunnel0, prefixlen 24
NHRP: netid_out 1, netid_in 1
NHRP: nhrp_cache_lookup_comp returned 0x4B423138
NHRP: Forwarding request due to authoritative request.
NHRP: Attempting to forward to destination: 172.16.123.3
NHRP: Forwarding: NHRP SAS picked source: 172.16.123.1 for destination: 172.16.123.3
NHRP: Attempting to send packet via DEST 172.16.123.3
NHRP: NHRP successfully resolved 172.16.123.3 to NBMA 192.168.123.3
NHRP: Encapsulation succeeded.  Tunnel IP addr 192.168.123.3
NHRP: Forwarding Resolution Request via Tunnel0 vrf 0, packet size: 105
      src: 172.16.123.1, dst: 172.16.123.3
NHRP: 129 bytes out Tunnel0
Above you can see that the hub receives a NHRP resolution request from spoke1. It checks it’s cache to see if it knows how to reach spoke1 and it does find an entry because the spoke1 router has already registered himself. The hub router will then forward this resolution request to the spoke2 router.
Here’s what it looks like on spoke1:
Spoke1#
NHRP: NHRP could not map 172.16.123.3 to NBMA, cache entry not found
NHRP: MACADDR: if_in null netid-in 0 if_out Tunnel0 netid-out 1
NHRP: Sending packet to NHS 172.16.123.1 on Tunnel0
NHRP: NHRP successfully resolved 172.16.123.1 to NBMA 192.168.123.1
NHRP: Checking for delayed event /172.16.123.3 on list (Tunnel0).
NHRP: No node found.
NHRP: Adding Tunnel Endpoints (VPN: 172.16.123.3, NBMA: 192.168.123.1)
NHRP: Successfully attached NHRP subblock for Tunnel Endpoints         (VPN: 172.16.123.3, NBMA: 192.168.123.1)
NHRP: Enqueued NHRP Resolution Request for destination: 172.16.123.3
NHRP: Sending NHRP Resolution Request for dest: 172.16.123.3 to nexthop: 172.16.123.1 using our src: 172.16.123.2
NHRP: Attempting to send packet via DEST 172.16.123.1
NHRP: Encapsulation succeeded.  Tunnel IP addr 192.168.123.1
NHRP: Send Resolution Request via Tunnel0 vrf 0, packet size: 85
      src: 172.16.123.2, dst: 172.16.123.1
NHRP: 109 bytes out Tunnel0
NHRP: Receive Resolution Reply via Tunnel0 vrf 0, packet size: 133
NHRP: netid_in = 0, to_us = 1
NHRP: No need to delay processing of resolution event nbma src:192.168.123.2 nbma dst:192.168.123.3
NHRP: Adding Tunnel Endpoints (VPN: 172.16.123.3, NBMA: 192.168.123.3)
NHRP: Cleanup up 0 stale cache entries
NHRP: Successfully attached NHRP subblock for Tunnel Endpoints         (VPN: 172.16.123.3, NBMA: 192.168.123.3)172.16.123.1
Above you can see that spoke1 checks its NHRP cache and doesn’t know the NBMA address for 172.16.123.3. It will then generate a NHRP resolution request and sends it to the hub router. It will then receive a NHRP resolution reply that carries the NBMA address of spoke2. Here’s what you will see on spoke2:
Spoke2#
NHRP: Receive Resolution Request via Tunnel0 vrf 0, packet size: 105
NHRP: netid_in = 1, to_us = 1
NHRP: request was to us, responding with ouraddress
NHRP: Checking for delayed event 172.16.123.2/172.16.123.3 on list (Tunnel0).
NHRP: No need to delay processing of resolution event nbma src:192.168.123.3 nbma dst:192.168.123.2
NHRP: Adding Tunnel Endpoints (VPN: 172.16.123.2, NBMA: 192.168.123.2)
NHRP: NHRP subblock already exists for Tunnel Endpoints         (VPN: 172.16.123.2, NBMA: 192.168.123.2)
NHRP: Cache already has a subblock node attached for                       Tunnel Endpoints (VPN: 172.16.123.2, NBMA: 192.168.123.2)
NHRP: Attempting to send packet via DEST 172.16.123.2
NHRP: Encapsulation succeeded.  Tunnel IP addr 192.168.123.2
NHRP: Send Resolution Reply via Tunnel0 vrf 0, packet size: 133
      src: 172.16.123.3, dst: 172.16.123.2
NHRP: 157 bytes out Tunnel0
Above you can see that spoke2 receives the NHRP resolution request that was forwarded from the hub to spoke2. It realizes that the request has one of its own addresses and decides to reply. It will create a NHRP resolution reply and forwards it to spoke1.
Here’s what the NHRP resolution request and reply look like in wireshark:
  • Full Access to 447 lessons.
Tags: , ,
  1. Avatar for hengsovandara1345 hengsovandara1345 says:
    Hello Rene
    Hub router already store NBMA of Spoke 2 when it was establish tunnel interface, but why when Spoke 1 send request NBMA address of spoke 2 to hub then hub need to forward it to spoke 2? why don’t it reply back directly to spoke 1?
    Hello Heng
    You are correct that the Hub router does know the NBMA of spoke 2, however, when an NBMA request is sent, it must always be answered by the owner of the specific address. In this example, Spoke 1 doesn’t have the 172.16.123.3 address in its NHRP cache. It sends out an NHRP resolution request. The resolution request is not sent to the Hub as its destination, but is sent to the hub as the the path to the destination , that is, via Tunnel 0.
    The NHRP resolution must always be answered by the owner of the IP address in question. In this case, it
  3. Avatar for hengsovandara1345 hengsovandara1345 says:
    Hello Lazaros
    I got this now, It mean Spoke 1 send use Hub as it path to send NHRP resolution request to spoke 2.
    Thank you so much .
  4. Avatar for hengsovandara1345 hengsovandara1345 says:
    Hello
    I shut down HUB after spoke already establish dynamic connection between them. and all spoke and HUB are running RIP to advertise their loopback. since i shut down the HUB and clear IP route on spoke i found that RIP is never recover. it lost all route to loopback of another spoke.
  5. Avatar for jose.gro1992 jose.gro1992 says:
    There is something I did not understand, general speaking, when we use RIP, do not the interfaces sending the routes to another device, announce themself are the next hop? (same way as with EIGRP) .
    For DMVPN Phase 2 output
    Is showing 172.16.123.2 as the next hop indeed for 2.2.2.2 but metric is still 2, so does not that mean the
10 more replies! Ask a question or join the discussion by visiting our Community Forum
