EAPOL (Extensible Authentication Protocol over LAN)
IEEE 802.1X is an IEEE standard for port-based Network Access Control (PNAC). Devices wanting to access the network must authenticate themselves before accessing it. It’s commonly used in corporate networks where we require user or device authentication.
802.1X uses Extensible Authentication Protocol (EAP) to exchange authentication messages. EAP is not a protocol but an authentication framework as defined in RFC 3748.
EAP offers different authentication methods called EAP methods. Depending on the EAP method, you can use authentication methods such as passwords, token cards, smart cards, certificates, etc. Examples of EAP methods are EAP-MD5, EAP-TLS, EAP-TTLS, or PEAP.
EAP is always carried by another protocol. EAP was originally an authentication option for the point-to-point protocol (PPP). To transport EAP messages, we need to encapsulate them. EAPOL (Extensible Authentication Protocol over Local Area Network) encapsulates EAP packets within Ethernet frames.
The first version of EAPOL was designed for IEEE 802.3 Ethernet wired networks in 802.1X-2001 but has been modified for other network types, such as IEEE 802.11 wireless in 802.1X-2004, where we encapsulate EAPOL messages in 802.11 frames.
EAPOL was updated again in the 802.1X-2010 revision to incorporate support for MACsec, as defined in IEEE 802.1AE, and for Secure Device Identity (DevID) under IEEE 802.1AR.
802.1X has three main components:
  • Supplicant (client device)
  • Authenticator (network devices such as a switch or wireless access point)
  • Authentication server (typically RADIUS server)
Here is an example of where it is used:
Supplicant, authenticator and authentication server: EAPOL between supplicant and authenticator, RADIUS between authenticator and authentication server
We use EAPOL between the supplicant and the authenticator. Between the authenticator and authentication server, we use something else, usually RADIUS.
EAPOL is considered secure, but the security of EAPOL depends on the EAP method you use. For example, EAP-TLS provides strong security by using certificates where older methods, such as EAP-MP5, that only use a challenge are considered weak and vulnerable to attacks.
I’ll give you an overview of all EAPOL packets, messages and an explanation of its operation. We will also look at packet captures so you can see it in action.
802.1X Port Status
802.1X has two logical port entities for an authenticated port:
  • Uncontrolled port: always open to send and receive authentication packets.
  • Controlled port: blocks packets depending on the port state:
    • Authorized state: the controlled port is in the authorized state when the supplicant has passed authentication.
    • Unauthorized state: the controlled port is in the unauthorized state by default or when the supplicant has failed authentication.
The 802.1X Port Access Entity (PAE) uses the uncontrolled port to send and receive EAPOL packets. The authenticator changes the controlled port state based on the result of the EAP authentication. It can move from the unauthorized to the authorized state or vice versa. Here’s how to visualize this:
802.1X controlled port open and closed next to the always-open uncontrolled port, user data on the controlled port and EAPOL on the uncontrolled port
EAPOL Packets
EAPOL uses several different packets. Here is an overview:
  • EAPOL-Start
  • EAPOL-EAP
  • EAPOL-Key
  • EAPOL-Logoff
  • EAPOL-Encapsulated-ASF-Alert
  • EAPOL-MKA
Let’s go through them.
EAPOL-Start
The supplicant sends this packet when it wants to start the authentication process. When the authenticator receives this packet, it will transmit EAP-Request Identity messages to the supplicant.
EAPOL-EAP
This packet type transports EAP packets between the supplicant and the authenticator. It encapsulates EAP messages such as EAP-Request and EAP-Response messages.
EAPOL-Key
This packet is used to transport encryption keys and related data. You’ll see it when you use EAP methods that use encryption or in the Wi-Fi Protected Access (WPA) four-way handshake.
EAPOL-Logoff
Sent by the supplicant to the authenticator to terminate the authentication session. Once the authenticator receives an EAPOL-Logoff message, it will change the port state to unauthorized and discard the keys associated with that supplicant.
This is not a common packet to see, but this packet is used to encapsulate ASF (Alert Standard Format) alerts. ASF is used for remote monitoring and control of systems. This packet can be used to encapsulate these packets over EAPOL.
EAPOL-MKA
MKA stands for “MACsec Key Agreement” and is defined in IEEE 802.1X-2010. It provides the keys for MACsec, the IEEE 802.1AE standard for providing MAC-layer encryption over wired networks. EAPOL-MKA packets distribute key material and manage encryption keys for MACsec-enabled devices. This protocol is used to secure communication on the LAN between supported devices.
EAP Messages
EAP messages are the actual contents or data within the EAPOL-EAP packets. These are the messages used for the authentication process. Here is a list of general EAP messages that are commonly used:
  • EAP-Request/Identity
  • EAP-Response/Identity
  • EAP-Request/Challenge
  • EAP-Response/Challenge
  • EAP-Success
  • EAP-Failure
Keep in mind that these are general EAP messages. You’ll see some of these or customized messages depending on your EAP method. Here’s what these messages are used for:
Sent by the authenticator to request the identity of the supplicant.
Sent by the supplicant as a response to the EAP-Request/Identity message. Includes the identity of the supplicant.
Sent by the authenticator to the supplicant. This message includes a challenge when you use a challenge-response-based authentication EAP method such as EAP-MD5.
Sent by the supplicant, which includes a response to the challenge in the EAP Request/Challenge message.
EAP-Success
Sent by the authenticator to tell the supplicant that the authentication process is successful and that the supplicant is authenticated.
EAP-Failure
Sent by the authenticator when the authentication process fails.
Operation Overview
Here is a general overview of how EAPOL (and RADIUS) packets are exchanged. This operation and the actual messages exchanged depend on the EAP method you use. Let’s have a look:
EAPOL and RADIUS message exchange between supplicant, authenticator and authentication server, from EAPOL-Start to Port authorized, then EAPOL-Logoff and Port unauthorized
As you can see, we use EAPOL between the supplicant and the authenticator only. Let me walk you through this diagram:
  • The switch interface that connects to the supplicant is in an unauthorized state. All packets are denied except for EAPOL packets.
  • When the supplicant wants to access the network, it has to authenticate itself. It sends an EAPOL-Start packet to tell the authenticator it wants to authenticate.
  • The authenticator replies with an EAP packet containing a Request/Identity message, asking for the identity of the supplicant.
  • The supplicant replies with an EAP packet with a Response/Identity message containing its identity.
  • The authenticator forwards the supplicant’s identity to the authentication server in a RADIUS Access-Request packet.
  • The authentication server sends a challenge to the authenticator in a RADIUS Access-Challenge packet.
  • The authenticator forwards the challenge to the supplicant in an EAP packet containing the EAP-Request/Challenge message.
  • The supplicant includes its response to the challenge in an EAP packet in the Response/Challenge message.
  • The authenticator forwards the response to the authentication server in a RADIUS Access-Request packet.
  • The authentication server replies with a RADIUS Access-Accept packet.
  • The authenticator sends an EAP-success packet to the supplicant and sets the port to the authorized state.
  • When the supplicant wants to end the session, it sends an EAPOL-Logoff packet, and the authenticator resets the port to the unauthorized state.
Packet Capture
Capturing EAPOL packets is a good idea because you’ll be able to see the actual EAP messages in action.
Here is the topology I’ll use:
Lab topology: H1 on SW1 Gi1/0/11 and server S1 on SW1 Gi1/0/12
I’ll use the EAP-MD5 method because it’s one of the simplest EAP methods to set up. It’s insecure, so you shouldn’t use it in production anymore. EAP-MD only uses a challenge and response. Here are the devices I use:
  • The host is a Ubuntu machine. I like to use Ubuntu because it has 802.1X support and still supports EAP-MD5.
  • The switch is a Cisco catalyst 3850 running Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.07.05.E RELEASE SOFTWARE (fc1).
  • The RADIUS server is a freeradius server. You can use my freeradius image. It is simple to set up, and it supports many EAP methods.
Setting up 802.1X on Ubuntu is straightforward. Under network settings, you only have to enable 802.1X and specify the EAP method and credentials.Here it is:
Ubuntu 8021x Eap Md5
Want to take a look for yourself? Here, you will find the startup configuration of the authenticator (SW1) and the configuration files for the freeradius server.
SW1
hostname SW1
username admin privilege 15 secret 5 $1$YVOP$xaZpE.nA.FwvKwXxtvzTw1
aaa new-model
aaa authentication dot1x default group radius
aaa session-id common
ip dhcp pool VLAN10
 network 192.168.10.0 255.255.255.0
dot1x system-auth-control
interface GigabitEthernet1/0/11
 switchport access vlan 10
 switchport mode access
 authentication host-mode multi-auth
 authentication port-control auto
 dot1x pae authenticator
 spanning-tree portfast
interface GigabitEthernet1/0/12
interface Vlan10
 ip address 192.168.10.100 255.255.255.0
radius server FREERADIUS
 address ipv4 192.168.10.200 auth-port 1812 acct-port 1813
 key CISCO
docker-compose.yml
version: '2'
services:
 freeradius:
  image: networklessons/freeradius:latest
  ports:
   - 1812:1812/udp
   - 1813:1813/udp
  volumes:
   - "./clients.conf:/etc/freeradius/3.0/clients.conf"
   - "./users:/etc/freeradius/3.0/users"
   - "./eap:/etc/freeradius/3.0/mods-enabled/eap"
clients.conf
client CISCO {
  ipaddr                = 0.0.0.0/0
  secret                = CISCO
eap
eap {
        default_eap_type = md5
        timer_expire = 60
        ignore_unknown_eap_types = no
        cisco_accounting_username_bug = no
        max_sessions = ${max_requests}
        md5 {
users
ubuntu          Cleartext-Password := "ubuntu"
I’ll show you all the packets from both sides: EAPOL and RADIUS.
EAPOL
Let’s start with the EAPOL packets. If you want to see them for yourself, you can download them here:
Packet Capture: 802.1X EAP MD5 EAPOL
EAPOL-Start
The EAPOL-Start packet is the first one and is sent from the supplicant to the authenticator:
Frame 1: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface -, id 0
Ethernet II, Src: Solarfla_25:11:f0 (00:0f:53:25:11:f0), Dst: Nearest-non-TPMR-bridge (01:80:c2:00:00:03)
    Destination: Nearest-non-TPMR-bridge (01:80:c2:00:00:03)
    Source: Solarfla_25:11:f0 (00:0f:53:25:11:f0)
    Type: 802.1X Authentication (0x888e)
    Padding: 000000000000000000000000000000000000000000000000000000000000000000000000…
    Version: 802.1X-2001 (1)
    Type: Start (1)
    Length: 0
Here’s what we see:
  • The packet is destined for the Ethernet multicast address 0180:c200:0003.
  • The Ethertype is 0x888E.
  • The version is set to 802.1X-2001.
  • The type is “Start”.
The authenticator sends the EAP-Request/Identity packet to the supplicant:
Frame 2: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface -, id 0
Ethernet II, Src: Cisco_6f:77:8b (bc:c4:93:6f:77:8b), Dst: Solarfla_25:11:f0 (00:0f:53:25:11:f0)
    Destination: Solarfla_25:11:f0 (00:0f:53:25:11:f0)
    Source: Cisco_6f:77:8b (bc:c4:93:6f:77:8b)
    Version: 802.1X-2010 (3)
    Type: EAP Packet (0)
    Length: 5
    Code: Request (1)
    Length: 5
    Type: Identity (1)
The output above shows that the version is set to 802.1X-2010, and the type is an EAP packet. The EAP message shows that the code is set to request, and the type is identity.
The supplicant replies with the EAP-Response/Identity packet:
Frame 3: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface -, id 0
    Length: 11
    Code: Response (2)
    Length: 11
    Type: Identity (1)
    Identity: ubuntu
Above, we see that the code is set to response, and the type is identity. The identity shows “ubuntu”, the username I configured on my desktop.
The authenticator will forward the challenge from the RADIUS server to the supplicant in the EAP-Request/Challenge packet:
Frame 4: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface -, id 0
    Length: 22
    Code: Request (1)
    Length: 22
    Type: MD5-Challenge EAP (EAP-MD5-CHALLENGE) (4)
        [Expert Info (Warning/Security): Vulnerable to MITM attacks. If possible, change EAP type.]
            [Vulnerable to MITM attacks. If possible, change EAP type.]
            [Severity level: Warning]
            [Group: Security]
    EAP-MD5 Value-Size: 16
    EAP-MD5 Value: 07132be14ba1bfea95cfe460094a23fb
This output shows that the code is set to request, and the type is MD5-Challenge EAP. The challenge is included under the EAP-MD5 Value.
The supplicant will reply with the EAP-Response/Challenge packet:
Frame 5: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface -, id 0
    Length: 22
    Code: Response (2)
    Length: 22
            [Group: Security]
    EAP-MD5 Value: 6492f6ebd6ce9b437643ea37ac9b24c5
The code is set to response. The type is MD5-Challenge EAP. It also includes the response under EAP-MD5 Value.
EAP-Success
Finally, the supplicant receives the EAP-Success packet from the authenticator:
Frame 6: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface -, id 0
    Length: 4
    Code: Success (3)
    Length: 4
The code is set to Success.
RADIUS
While we are at it, let’s also look at the RADIUS packets. You can take a look for yourself here:
  • Full Access to 448 lessons.
Tags: ,
  1. Avatar for ckress ckress says:
    Doing some more research on this. Is this process described here for the wired EAPOL “handshake”. Is there different 4 way handshake used for wireless that uses PMK and GMK keys? Appreciate all the work you guys do!
    -Chase
    Hello Chase
    EAPOL and the WPA 4-way handshake are both important components in network security, especially in authentication processes. In the lesson, EAPOL is described in the context of wired network security, and in particular, with 802.1X authentication. It’s a part of the IEEE 802.1X standard for port-based Network Access Control (NAC).
    In this context, EAPOL and WPA 4-way handshake are quite different in their use and processes. Their key differences are listed below:
    Network Type: EAPOL is mainly used in wired networks, while the 4-way handshake
    @ckress I’m writing an explanation of the WPA 4-way handshake today, which should be finished in a couple of days. I’ll add a link here once it’s finished.
    Understanding the WPA keys is a prerequisite. I published this yesterday:
    https://networklessons.com/wir...erarchy-explained
    Here is an explanation of the WPA 4-way handshake:
    https://networklessons.com/wir...2-4-way-handshake
  5. Avatar for davidilles davidilles says:
    Hi, everyone.
    After seeing this
    Why are EAP messages such as request identity, etc encapsulated in an EAPOL header? Which is basically the part where it says 802.1X Authentication.
    Wouldn’t it make more sense to just grab those fields in EAP and include them in EAPOL altogether?
    Rene said that EAP messages are always carried by another protocol which is EAPOL in this case.. Are there any other protocols that can also carry EAP messages? What if EAPOL just wasn’t there? If we removed the
1 more reply! Ask a question or join the discussion by visiting our Community Forum
