Cisco WLC Deployment Models
Let’s say you want to deploy a WLC with multiple lightweight APs in your network. Where do you connect the WLC? In the core layer? The distribution or access layer? Or perhaps in the data center?
The Split-MAC architecture with the WLC and APs supports multiple deployment models. What is essential to understand is that data from wireless clients usually goes through the CAPWAP tunnel to the WLC. Mobility Express is an exception.
Each deployment model puts the WLC in a different location in the network. In this lesson, we’ll take a look at the various options and their pros/cons.
Unified WLC Deployment
With the centralized WLC deployment model, the WLC is a hardware appliance in a central location in the network. This deployment is a good choice if the majority of your wireless traffic is destined to the edge of your network, like the Internet or a data center. It’s easy to enforce security policies because all traffic ends up in a central location. Another name for this deployment is centralized WLC deployment.
Unified WLC connected to the core switch of a core, distribution and access network with lightweight APs
In the picture above, the unified WLC connects to the core layer. This deployment model supports up to 6000 APs per WLC. If you need more than 6000 APs, you need to add an extra WLC.
Cloud-based WLC Deployment
With the cloud-based WLC deployment model, we add the WLC to the data center in a private cloud. With this deployment model, the WLC is a virtual machine, not a physical appliance. The older AireOS virtual WLC supports up to 3000 APs. The Catalyst 9800-CL supports up to 6000 APs with its large profile. If you need more, you create another virtual machine.
Cloud WLC in the data center connected to the core switch of a core, distribution and access network
Don’t confuse this deployment model with cloud-based AP architecture like Cisco Meraki. With the Cisco Meraki architecture, the management function is in the cloud and we use autonomous APs on the network.
Embedded WLC Deployment
If you have a small number of APs, like in a small campus or branch location, then you can use an embedded WLC in switch stacks. This deployment option is a switch with an integrated WLC, and it supports up to 200 APs.
The APs don’t have to be physically connected to the switch that hosts the WLC. APs connected to other switches can join the WLC as well. When the number of APs increases, you can add additional switches with embedded WLCs. With the newer embedded wireless controller on Catalyst 9000 switches, the APs run in fabric mode, so client data traffic does not go to the WLC.
  • Full Access to 448 lessons.
  1. Avatar for martinkuntov martinkuntov says:
    Great overview, thanks :slight_smile:
    Kind regards,
    Martin
  2. Avatar for curtis.padgett curtis.padgett says:
    In the Cisco ENCOR Blueprint it mentions models like centralized, distributed, and controller-less. I can see that Unified is the centralized model, and possible distributed is the embedded, but what about the controller-less model. Which one of models mentioned in this video would be controller-less? Am I right about the embedded?
    Hello Curtis
    The https://learningnetwork.cisco....encor-exam-topics does indeed outline the wireless deployment models that you mention. Specifically:
    1.2 Describe wireless network design principles
    1.2.a Wireless deployment models (centralized, distributed, controller-less, controller-based, cloud, remote branch)
    These are covered in the lessons like so:
    Centralized uses a dedicated hardware/appliance Wireless LAN Controller (WLC) in a central location, managing all APs. It provides unified configuration, RF management, and policy enforcement. This
  4. Avatar for davidilles davidilles says:
    Hello everyone.
    My book describes the following:
    Catalyst 9800 Embedded Wireless for a Switch
    Catalyst 9800 wireless controller software for the Cisco Catalyst 9300 switch brings the wired and wireless infrastructure together with consistent policy and management. The Cisco Catalyst 9800 embedded wireless controller software package can be installed on Cisco Catalyst 9300 Series switches to enable wireless controller functionality for distributed branches and small campuses.
    Catalyst 9800 Embedded Wireless for an AP
    The Cisco Embedded Wireless Controller
    davidilles:
    What is the difference between EWC and Mobility Express? Is EWC the more modern option for 9800 WLCs while Mobiliy Express was for older APs/AireOS WLCs?
    EWC runs on modern IOS-XE platforms, including the newer Cisco Catalyst 9100 Access Points. This is the same software platform as the 9800 series controllers. So it’s a scaled down version of the same software as the independent controller running on the switch, but it runs on the specific series of access points.
    Cisco Mobility Express is based on the older AirOS platform and
2 more replies! Ask a question or join the discussion by visiting our Community Forum
