Redistribution between OSPF and RIP
In a previous lesson, I explained the basics of Redistribution. Now it’s time actually to configure some redistribution. In this lesson, we’ll cover redistribution between OSPF and RIP. This is the topology that we will use:
OSPF RIP Redistribution R1 R2 R3
Let’s start with the redistribution between OSPF and RIP.
First, let me show you the router configurations:
R1(config)#router ospf 1
R1(config-router)#network 1.1.1.0 0.0.0.255 area 0
R2(config)#router ospf 1
R2(config)#router rip
R2(config-router)#version 2
R3(config)#router rip
R3(config-router)#version 2
R3(config-router)#network 3.3.3.0
Nothing special here, just OSPF and RIP advertising their networks.
R1#show ip route
C       1.1.1.0 is directly connected, Loopback0
R2#show ip route
O       1.1.1.1 [110/2] via 192.168.12.1, 00:11:05, FastEthernet0/0
R       3.3.3.0 [120/1] via 192.168.23.3, 00:00:20, FastEthernet1/0
C    192.168.23.0/24 is directly connected, FastEthernet1/0
R3#show ip route
C       3.3.3.0 is directly connected, Loopback0
C    192.168.23.0/24 is directly connected, FastEthernet0/0
You can see router R2 has learned RIP and OSPF information. Time for some redistribution action!
🔥 2391 people registered in the last 30 days
  1. Can we redistribute OSPF one area in to OSPF different area?
  2. Hi Sathmal,
    Nope it’s impossible, you can’t redistribute one process into the same process.
  3. Hi Rene,
    I am confused with the following redistribution command: metric-type 1 when redistribute between eigrp into ospf.
    R3(config)#router ospf 1
    R3(config-router)#redistribute eigrp 100 metric-type 1 subnets
  4. Hi Rene,
    Thank you for this lesson.
    what exactly is the use of the ‘default-metric’ command? While redistributing routes can i use any metric in the command?
    Example:
    John(config-router)#redistribute ospf 1 metric
  5. Hi Abhishek,
    If you redistribute into EIGRP or RIP then the default metric is set to “infinity”. You can use the default-metric command to set a default metric globally or configure it each time when you use the “redistribute” command.
34 more replies! Ask a question or join the discussion by visiting our Community Forum
