The most common way for the last thirty years to configure our network devices is the command-line interface (CLI). The CLI is great for humans, but not so great for computers.
We use configuration commands to configure everything and show or debug commands to verify our work. The output of show (and debug) commands is formatted, so it’s easy to read for humans. However, it’s a pain to use the CLI for scripts or network automation tools. You have to parse a show command to get the information you want, and the output is different for each show command.
Configuration commands are also an issue. On Cisco IOS, when you enter a command, there is no confirmation of whether the router or switch accepts the command or not. You only see the empty prompt. If you paste a lot of commands, sometimes the console can’t keep up. For us humans, it’s easy to spot this and work around it. For CLI scripts or network automation tools, it’s a problem and you have to take this into account.
An alternative to the CLI to configure network devices is through application programming interfaces (APIs). APIs use data formats to exchange information. In this lesson, we’ll discuss the most popular data formats and structures. We’ll also take a look at YANG data models.
Data Formats
There are two common data formats that APIs often use:
- Extensible Markup Language (XML)
- JavaScript Object Notation (JSON)
We also call these data formats “data serialization languages”. Another data format we often use for device configuration is YAML. A good example for this is Ansible. Let’s talk about these three data formats.
XML is a tag-based language and if you know HTML, this will look familiar.
Each item you add has to start with < and end with >. Here is a simple example:
<router>
<name>CSR1000V</name>
<vendor>Cisco</vendor>
<type>virtual</type>
</router>
<router>
<name>1921</name>
<type>hardware</type>
</router>
</devices>
The output above shows the tag with two tags in it. The first tag contains information about a CSR1000V router. The second tag contains information about a 1921 router.
Let me show you the output of an actual router. Here is the output of show running-configuration as seen from the CLI:
hostname R1
ip cef
interface GigabitEthernet0/1
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
duplex auto
speed auto
media-type rj45
In XML, it looks like this:
R1# show running-config | format
<?xml version="1.0" encoding="UTF-8"?>
<Device-Configuration
xmlns="urn:cisco:xml-pi">
<version>
<Param>15.6</Param>
</version>
<service>
<timestamps>
<debug>
<datetime>
<msec/>
</datetime>
</debug>
</timestamps>
</service>
<service>
<timestamps>
<log>
<datetime>
<msec/>
</datetime>
</log>
</timestamps>
</service>
<service operation="delete" >
<password-encryption/>
</service>
<hostname>
<SystemNetworkName>R1</SystemNetworkName>
</hostname>
<ip>
<cef/>
</ip>
<interface>
<Param>GigabitEthernet0/1</Param>
<ConfigIf-Configuration>
<ip>
<address>
<IPAddress>192.168.12.1</IPAddress>
<IPSubnetMask>255.255.255.0</IPSubnetMask>
</address>
</ip>
<duplex>
<auto/>
</duplex>
<speed>
<auto/>
</speed>
<media-type>
<rj45/>
</media-type>
</ConfigIf-Configuration>
</interface>
<interface>
<Param>GigabitEthernet0/2</Param>
<ip>
<address>
<IPAddress>192.168.1.254</IPAddress>
</address>
</ip>
<duplex>
<auto/>
</duplex>
<speed>
<auto/>
</speed>
<media-type>
<rj45/>
</media-type>
</interface>
<end></end>
</Device-Configuration>
One more example. Here is show arp with the CLI output:
R1# show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.1.1 67 fa16.3ee0.d9a3 ARPA FastEthernet0/0
Internet 192.168.1.2 8 fa16.3ee0.c9b2 ARPA FastEthernet0/0
Internet 192.168.1.3 - fa16.3ee0.a5a5 ARPA FastEthernet0/0
And in XML, it looks like this:
<ShowArp xmlns="ODM://disk0:/spec.odm//show_arp">
<ARPTable>
<entry>
<Protocol>Internet</Protocol>
<Address>192.168.1.1</Address>
<Age>67</Age>
<MAC>fa16.3ee0.d9a3</MAC>
<Type>ARPA</Type>
<Interface>FastEthernet0/0</Interface>
</entry>
<entry>
<Address>192.168.1.2</Address>
<Age>8 </Age>
<MAC>fa16.3ee0.c9b2</MAC>
<Type>ARPA</Type>
</entry>
<entry>
<Address>192.168.1.3</Address>
<MAC>fa16.3ee0.a5a5</MAC>
<Type>ARPA</Type>
</entry>
</ARPTable>
</ShowArp>
These XML outputs are indented which makes them easier to read for us humans. Indentation however, is not a requirement of XML.
JSON is newer than XML and has a simple syntax. JSON stores information in key-value pairs and uses objects for its format. It’s easier to read and has less overhead than XML.
- Objects start with { and end with }.
- Commas separate objects.
- Double quotes wrap names and strings.
- Lists start with [ and end with ].
Let’s convert our first XML example into JSON.
XML:
<router>
</router>
<router>
<name>1921</name>
</router>
</devices>
JSON:
"devices": {
"router": [
"name": "CSR1000V",
"vendor": "Cisco",
"type": "virtual"
"name": "1921",
"vendor": "Cisco",
"type": "hardware"
If you look at the output above, you can see we used the tag twice in XML. In JSON, we only need a single “router” object. This is a list with two objects.
YAML (YAML Ain’t Markup Language)
According to the official website, YAML is a human friendly data serialization standard for all programming languages. YAML is a superset of JSON. This means that a YAML parser understands JSON, but not necessarily the other way around.
YAML is easier to look at than XML or JSON.
- Key-value pairs are separated by : (colon).
- Lists begin with a – (hyphen).
- Indentation is a requirement. You have to use spaces, you can’t use tabs.
- You can add comments with a #.
We often use YAML files for configuration management because it’s easy to read and comments are useful.
Let’s compare JSON with YAML. Here’s the JSON object I showed you before:
JSON:
"devices": {
"router": [
"name": "CSR1000V",
"vendor": "Cisco",
"type": "virtual"
"name": "1921",
"vendor": "Cisco",
"type": "hardware"
Here it is in YAML:
devices:
router:
- name: CSR1000V
vendor: Cisco
type: virtual
- name: 1921
vendor: Cisco
type: hardware
YAML is easier to read without the commas and brackets of JSON. One disadvantage of YAML is that indentation with spaces is a requirement. It’s easy to make indentation errors where you have a space too few or too many.
Data Models
Data models describe the things you can configure, monitor, and the actions you can perform on a network device. In this section, we will discuss YANG.
Yet Another Next Generation (YANG)
SNMP is widely used to monitor networks. You can use SNMP to configure network devices, but in reality we don’t use it much. CLI scripting is a more popular option.
YANG is a modeling language and uses data models that are similar to SNMP Management Information Base (MIBs). YANG is a standard, described in RFC 6020 and increasing in popularity. YANG uses data models that describe:
- What you can configure on a device.
- What you can monitor on a device.
- Administrative actions you can perform on a device like clearing interface counters or resetting the OSPF process.
YANG Data models can be:
- Common data models: industry-wide standard YANG models from organizations like IETF and IEEE.
- Vendor data models: specific models that only apply to products or features from a vendor.
These data models allow a uniform way for us to configure, monitor, and interact with network devices. Network automation tools like NETCONF, RESTCONF, and gRPC require YANG data models. YANG uses a hierarchical tree structure, similar to the XML data format. There is a clear distinction between configuration data and state information.
A YANG module defines a data model through the data of a network device, and the hierarchical organization and constraints of that data. YANG identifies each module with a namespace URL.
You can find a collection of YANG modules in the YANG git repository. In this repository, there are also Cisco modules. For example, take a look at the modules for IOS XE 16.10.1
There are many module files in the repository. Here is the ARP module to create a static ARP entry:
Hi There,
Recently, the organization that I’m working for is starting to implement something called Software Defined Networking, SD-Access. I was wondering if we have a topic for this technology in this website.
If you have please share it with me. I’m trying to read this topic and get familiar with it.
Hello Mustafa
Under the Evolving Technologies section whose link you see below, there is Unit 2 which is called Network Programmability that deals with SDN. You can take a look at those lessons which should cover what you need.
https://networklessons.com
SD-Access is something you will also find in the following lesson:
https://networklessons.com/cloud-and-virtualization/cloud-connectivity
Look them over and if you have any more specific questions, just let us know!
Thank Mr. Lagapides !
This is a great section you showed me sir
Curious in Yang Git Hub , under vendor list, i only see Cisco and Juniper. If other network vendor like Arista, Alcatel are not there; does that mean their device does NOT support YANG model ?
if not, how do people use Netconf/restconf/gRPC to do automation with them ? (as all these protocols rely on YANG model)
Hello Samson
Arista does support Yang models on Github, and you can find those at the following link:
https://github.com/aristanetworks/yang
For other vendors, you may not find repositories and you may have to create them yourself. To determine if a particular vendor supports some form of automation, I suggest you research or contact the specific vendor in question. They will then lead you to the most appropriate solution.
