This packet capture contains an OSPF Link State Update with the router LSA of a router that is configured with max-metric router-lsa. That command turns the router into a “stub router”: it stays in the topology, but every link it advertises gets the maximum metric of 65535, so other routers only send transit traffic through it as a last resort.
The only thing that changes in the LSA is the metric on each link. The OSPF stub router lesson explains when you use max-metric, for example during a reload or maintenance. More captures are in the Packet Capture Library.
Want to open this capture in Wireshark yourself? The pcap file is free with a NetworkLessons account. Your free account also unlocks all our free lessons and every capture in the Packet Capture Library.
Create a free account to download the pcap
Already have an account? Log in and the download button appears here.
Capture overview
| File | ospf-lsa-type-1-router-max-metric.pcapng |
| Packets | 1 |
| Protocol | OSPFv2 (RFC 2328), stub router advertisement (RFC 6987) |
| Transport | IP protocol 89, from 192.168.12.2 to 224.0.0.5 |
| Devices | Cisco IOS router with router ID 2.2.2.2, area 0 |
| Wireshark filter | ospf.lsa.router.metric0 == 65535 or ospf |
Packet walkthrough
The LS Update (packet 1)
Open Shortest Path First
OSPF Header
Version: 2
Message Type: LS Update (4)
Packet Length: 76
Source OSPF Router: 2.2.2.2
Area ID: 0.0.0.0 (Backbone)
Checksum: 0x396a [correct]
Instance ID: Base IPv4 Unicast Instance (0)
Auth Type: Null (0)
LS Update Packet
Number of LSAs: 1
LSA-type 1 (Router-LSA), len 48
.000 0000 0000 0001 = LS Age (seconds): 1
0... .... .... .... = Do Not Age Flag: 0
Options: 0x22, (DC) Demand Circuits, (E) External Routing
..1. .... = (DC) Demand Circuits: Supported
.... ..1. = (E) External Routing: Capable
LS Type: Router-LSA (1)
Link State ID: 2.2.2.2
Advertising Router: 2.2.2.2
Sequence Number: 0x80000004
Checksum: 0xc752
Length: 48
Flags: 0x00
Number of Links: 2
Type: Transit ID: 192.168.24.4 Data: 192.168.24.2 Metric: 65535
Link ID: 192.168.24.4 - IP address of Designated Router
Link Data: 192.168.24.2
Link Type: 2 - Connection to a transit network
Number of Metrics: 0 - TOS
0 Metric: 65535
Type: Transit ID: 192.168.12.2 Data: 192.168.12.2 Metric: 65535
Link ID: 192.168.12.2 - IP address of Designated Router
Link Data: 192.168.12.2
0 Metric: 65535
Here’s what stands out:
- LS Update, one router LSA (type 1): router 2.2.2.2 floods its own LSA after the configuration change. LS Age 1 means it’s brand new.
- Sequence Number 0x80000004: every new version of the LSA gets a higher sequence number. The first one a router creates is 0x80000001, so this router has updated its LSA three times.
- Two transit links: connections to the networks with DRs 192.168.24.4 and 192.168.12.2.
- Metric 65535 on both: 0xFFFF, the highest value that fits in the 16-bit metric field. The normal metric would be the interface cost, for example 10. Other routers still compute paths through this router, but any path with a normal metric wins.
- Flags: no bits set: max-metric doesn’t use a flag of its own. You can only recognize a stub router by its metrics.
