FlexVPN is Cisco’s solution to configure IPSec VPN with IKEv2. You can use this for different VPN types, including site-to-site VPNs. Thanks to smart defaults, there are only a few items we have to configure. In this lesson, I’ll show you how to configure FlexVPN site-to-site between two routers using smart defaults.
This is the topology we are going to use:
We have two routers. On each router, we configure a static tunnel interface that we use for our FlexVPN site-to-site connection. I’m using IOSv Version 15.9(3)M2. There are three items we need to configure:
- Keyring.
- IKEv2 profile.
- Tunnel interface.
R1
hostname R1
ip cef
interface GigabitEthernet0/0
R2
hostname R2
ip cef
I’ll walk you through the different components one by one.
R1
Let’s start with R1.
Keyring
First, we configure a keyring. This is where we specify the pre-shared keys we want to use with the remote router:
R1(config)#crypto ikev2 keyring KEYRING
R1(config-ikev2-keyring)#peer R2
R1(config-ikev2-keyring-peer)#address 192.168.12.2
R1(config-ikev2-keyring-peer)#pre-shared-key local CISCO
R1(config-ikev2-keyring-peer)#pre-shared-key remote CISCO
IKEv2 Profile
Now we can create an IKEv2 profile. This is where we configure the identities of our routers, the authentication we want to use, and the keyring we want to use:
R1(config)#crypto ikev2 profile default
R1(config-ikev2-profile)#match identity remote fqdn R2.NWL.LAB
R1(config-ikev2-profile)#identity local fqdn R1.NWL.LAB
R1(config-ikev2-profile)#authentication local pre-share
R1(config-ikev2-profile)#authentication remote pre-share
R1(config-ikev2-profile)#keyring local KEYRING
In the configuration above, I picked the name “default”. There is no default IKEv2 profile on the router but I do this for a reason. The default IPSec profile is configured to use an IKEv2 profile named “default”. I’ll show you this when we verify our configuration.
Tunnel
The last item to configure is a tunnel interface. We create one and add the default IPSec profile here:
R1(config)#interface Tunnel 0
R1(config-if)#ip address 172.16.12.1 255.255.255.0
R1(config-if)#tunnel source gigabitEthernet 0/0
R1(config-if)#tunnel destination 192.168.12.2
R1(config-if)#tunnel protection ipsec profile default
This completes our configuration on R1.
R2
Let’s do the exact same thing on R2:
R2(config)#crypto ikev2 keyring KEYRING
R2(config-ikev2-keyring)# peer R1
R2(config-ikev2-keyring-peer)#address 192.168.12.1
R2(config-ikev2-keyring-peer)#pre-shared-key local CISCO
R2(config-ikev2-keyring-peer)#re-shared-key remote CISCO
R2(config)#crypto ikev2 profile default
R2(config-ikev2-profile)#match identity remote fqdn R1.NWL.LAB
R2(config-ikev2-profile)#identity local fqdn R2.NWL.LAB
R2(config-ikev2-profile)#authentication remote pre-share
R2(config-ikev2-profile)#authentication local pre-share
R2(config-ikev2-profile)#keyring local KEYRING
R2(config)#interface Tunnel0
R2(config-if)#ip address 172.16.12.2 255.255.255.0
R2(config-if)#tunnel source GigabitEthernet0/0
R2(config-if)#tunnel destination 192.168.12.1
R2(config-if)#tunnel protection ipsec profile default
This completes our configuration on both routers.
Verification
Let’s figure out whether our site-to-site VPN works. I’ll send a ping between the tunnel interfaces to trigger the VPN:
R1#ping 172.16.12.2
Sending 5, 100-byte ICMP Echos to 172.16.12.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/5/6 ms
Our ping works, but that doesn’t prove much. Let’s continue and check everything.
IKEv2
Let’s take a look at the default IKEv2 policy:
R1#show crypto ikev2 policy
IKEv2 policy : default
Match fvrf : any
Match address local : any
Proposal : default
In the output above, we see that the IKEv2 policy uses the default IKEv2 proposal. Let’s take a look at that:
R1#show crypto ikev2 proposal
IKEv2 proposal: default
Encryption : AES-CBC-256 AES-CBC-192 AES-CBC-128
Integrity : SHA512 SHA384 SHA256 SHA96 MD596
PRF : SHA512 SHA384 SHA256 SHA1 MD5
DH Group : DH_GROUP_1536_MODP/Group 5 DH_GROUP_1024_MODP/Group 2
And let’s check the IKEv2 profile that we configured:
R1#show crypto ikev2 profile
IKEv2 profile: default
Ref Count: 5
Match criteria:
Fvrf: global
Local address/interface: none
Identities:
fqdn R2.NWL.LAB
Certificate maps: none
Local identity: fqdn R1.NWL.LAB
Remote identity: none
Local authentication method: pre-share
Remote authentication method(s): pre-share
EAP options: none
Keyring: KEYRING
Trustpoint(s): none
Lifetime: 86400 seconds
DPD: disabled
NAT-keepalive: disabled
Ivrf: none
Virtual-template: none
mode auto: none
AAA AnyConnect EAP authentication mlist: none
AAA EAP authentication mlist: none
AAA Accounting: none
AAA group authorization: none
AAA user authorization: none
Do we have a Security Association (SA)? Let’s find out:
R1#show crypto ikev2 sa detailed
IPv4 Crypto IKEv2 SA
Tunnel-id Local Remote fvrf/ivrf Status
1 192.168.12.1/500 192.168.12.2/500 none/none READY
Encr: AES-CBC, keysize: 256, PRF: SHA512, Hash: SHA512, DH Grp:5, Auth sign: PSK, Auth verify: PSK
Life/Active Time: 86400/2074 sec
CE id: 1034, Session-id: 22
Status Description: Negotiation done
Local spi: C403D41F6A568C36 Remote spi: 554A2F783C96DA45
Local id: R1.NWL.LAB
Remote id: R2.NWL.LAB
Local req msg id: 2 Remote req msg id: 0
Local next msg id: 2 Remote next msg id: 0
Local req queued: 2 Remote req queued: 0
Local window: 5 Remote window: 5
DPD configured for 0 seconds, retry 0
Fragmentation not configured.
Dynamic Route Update: disabled
Extended Authentication not configured.
NAT-T is not detected
Cisco Trust Security SGT is disabled
Initiator of SA : Yes
IPv6 Crypto IKEv2 SA
We do have an IKEv2 SA. There is one more command that gives a similar output:
