FlexVPN Site-to-Site without Smart Defaults
In our FlexVPN site-to-site smart defaults lesson, we configure a site-to-site VPN using smart defaults. In this lesson, we’ll configure the same thing but we are not going to use smart defaults. This means we have to configure all of this:
  • IKEv2
    • IKEv2 Proposal
    • IKEv2 Policy
    • IKEv2 Keyring
    • IKEv2 Profile
  • IPSec
    • IPSec Transform-set
    • IPSec Profile
I’ll walk you through the entire configuration and we’ll take a look at some show commands to verify our work.
This is the topology we are going to use:
Flexvpn Site To Site Smart Defaults Lab Topology
We have two routers with a static tunnel interface. I’m using IOSv Version 15.9(3)M2.
R1
hostname R1
ip cef
interface GigabitEthernet0/0
R2
hostname R2
ip cef
R1
Let’s start with R1.
IKEv2
There are four IKEv2 components we need to configure:
  • IKEv2 Proposal
  • IKEv2 Policy
  • IKEv2 Keyring
  • IKEv2 Profile
IKEv2 Proposal
The proposal is a collection of items we use in the negotiation of the IKEv2 security association (SA). Let’s configure one:
R1(config)#crypto ikev2 proposal IKEV2_PROPOSAL
R1(config-ikev2-proposal)#encryption aes-cbc-256
R1(config-ikev2-proposal)#group 15
R1(config-ikev2-proposal)#integrity sha256
IKEv2 Policy
We also need an IKEv2 policy. This policy contains proposals we want to use in the negotiation. We create a new policy and refer to the proposal we just created:
R1(config)#crypto ikev2 policy IKEV2_POLICY
R1(config-ikev2-policy)#proposal IKEV2_PROPOSAL
IKEv2 Keyring
We need a keyring that contains the pre-shared key(s) we want to use.
R1(config)#crypto ikev2 keyring IKEV2_KEYRING
R1(config-ikev2-keyring)#peer R2
R1(config-ikev2-keyring-peer)#address 192.168.12.2
R1(config-ikev2-keyring-peer)#pre-shared-key local CISCO
R1(config-ikev2-keyring-peer)#pre-shared-key remote CISCO
IKEv2 Profile
In the IKEv2 profile, we configure the local and remote identity and the authentication we want to use. This is where we refer to the keyring we created:
R1(config)#crypto ikev2 profile IKEV2_PROFILE
R1(config-ikev2-profile)#match identity remote fqdn R2.NWL.LAB
R1(config-ikev2-profile)#identity local fqdn R1.NWL.LAB
R1(config-ikev2-profile)#authentication local pre-share
R1(config-ikev2-profile)#authentication remote pre-share
R1(config-ikev2-profile)#keyring local IKEV2_KEYRING
This completes our IKEv2 configuration on R1.
IPSec
Next up is IPSec.
IPSec Transform-Set
The transform-set is where we configure the encryption and hashing algorithms we want to use:
R1(config)#crypto ipsec transform-set IPSEC_TRANSFORM_SET esp-aes 256 esp-sha256-hmac
The default IPSec mode is tunnel mode. If you want to use transport mode, you can configure it under the transform-set.
IPSec Profile
The second part of the IPSec configuration is the profile. This is where we combine the IKEv2 profile and our IPSec transform-set:
R1(config)#crypto ipsec profile IPSEC_PROFILE
R1(ipsec-profile)#set ikev2-profile IKEV2_PROFILE
R1(ipsec-profile)#set transform-set IPSEC_TRANSFORM_SET
This completes the IPSec configuration.
Tunnel Interface
The last part of our site-to-site configuration is the tunnel interface. This is where we attach the IPSec profile:
R1(config)#interface tunnel 0
R1(config-if)#ip address 172.16.12.1 255.255.255.0
R1(config-if)#tunnel source gigabitEthernet 0/0
R1(config-if)#tunnel destination 192.168.12.2
R1(config-if)#tunnel protection ipsec profile IPSEC_PROFILE
And that wraps up our VPN configuration on R1.
R2
We’ll do the exact same thing on R2. Here are all the commands:
R2(config)#crypto ikev2 proposal IKEV2_PROPOSAL
R2(config-ikev2-proposal)#encryption aes-cbc-256
R2(config-ikev2-proposal)#integrity sha256
R2(config-ikev2-proposal)#group 15
R2(config)#crypto ikev2 policy IKEV2_POLICY
R2(config-ikev2-policy)#proposal IKEV2_PROPOSAL
R2(config)#crypto ikev2 keyring IKEV2_KEYRING
R2(config-ikev2-keyring)#peer R1
R2(config-ikev2-keyring-peer)#address 192.168.12.1
R2(config-ikev2-keyring-peer)#pre-shared-key local CISCO
R2(config-ikev2-keyring-peer)#pre-shared-key remote CISCO
R2(config)#crypto ikev2 profile IKEV2_PROFILE
R2(config-ikev2-profile)#match identity remote fqdn R1.NWL.LAB
R2(config-ikev2-profile)#identity local fqdn R2.NWL.LAB
R2(config-ikev2-profile)#authentication remote pre-share
R2(config-ikev2-profile)#authentication local pre-share
R2(config-ikev2-profile)#keyring local IKEV2_KEYRING
R2(config)#crypto ipsec transform-set IPSEC_TRANSFORM_SET esp-aes 256 esp-sha256-hmac
R2(config)#crypto ipsec profile IPSEC_PROFILE
R2(ipsec-profile)#set transform-set IPSEC_TRANSFORM_SET
R2(ipsec-profile)#set ikev2-profile IKEV2_PROFILE
R2(config)#interface Tunnel0
R2(config-if)#ip address 172.16.12.2 255.255.255.0
R2(config-if)#tunnel source GigabitEthernet0/0
R2(config-if)#tunnel destination 192.168.12.1
R2(config-if)#tunnel protection ipsec profile IPSEC_PROFILE
That’s all we need.
Disable Smart Defaults
Optionally, you can disable the smart defaults if you want. Since we configure everything manually, you might have a good reason not to use smart defaults. You can disable them by adding no in front of them:
R1 & R2
(config)#no crypto ikev2 policy default
(config)#no crypto ipsec profile default
(config)#no crypto ipsec transform-set default
(config)#no crypto ikev2 proposal default
When you disable a default, it loses all user configuration. You can re-enable a default by using the command again. For example: crypto ikev2 proposal default will re-enable the default IKEv2 proposal and restores the default values.
Verification
Let’s verify our work. First, I send some pings to the other end of the tunnel to trigger our VPN:
R1#ping 172.16.12.2
Sending 5, 100-byte ICMP Echos to 172.16.12.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/5/7 ms
Our pings are working, but to be sure let’s try some IKEv2 and IPSec show commands.
IKEv2
Let’s check out our IKEv2 policy:
R1#show crypto ikev2 policy
 IKEv2 policy : IKEV2_POLICY
      Match fvrf  : global
      Match address local : any
      Proposal    : IKEV2_PROPOSAL
 IKEv2 policy : default Disabled
This tells me the name of our policy and the proposal it uses, and it also shows us that the default policy is disabled. Let’s take a closer look at our proposal:
R1#show crypto ikev2 proposal
 IKEv2 proposal: IKEV2_PROPOSAL
     Encryption : AES-CBC-256
     Integrity  : SHA256
     PRF        : SHA256
     DH Group   : DH_GROUP_3072_MODP/Group 15
 IKEv2 proposal: default Disabled
Above, we see our proposal and it also tells us that the default proposal is disabled. Let’s check our profile:
R1#show crypto ikev2 profile
IKEv2 profile: IKEV2_PROFILE
 Ref Count: 5
 Match criteria:
  Fvrf: global
  Local address/interface: none
  Identities:
   fqdn R2.NWL.LAB
  Certificate maps: none
 Local identity: fqdn R1.NWL.LAB
 Remote identity: none
 Local authentication method: pre-share
 Remote authentication method(s): pre-share
 EAP options: none
 Keyring: IKEV2_KEYRING
 Trustpoint(s): none
 Lifetime: 86400 seconds
 DPD: disabled
 NAT-keepalive: disabled
 Ivrf: none
 Virtual-template: none
 mode auto: none
 AAA AnyConnect EAP authentication mlist: none
 AAA EAP authentication mlist: none
 AAA Accounting: none
 AAA group authorization: none
 AAA user authorization: none
The output above gives us an overview of the identities and keyring we use. Now to the important part; do we have an SA?
R1#show crypto ikev2 sa detailed
 IPv4 Crypto IKEv2  SA
Tunnel-id Local                 Remote                fvrf/ivrf            Status
1         192.168.12.1/500      192.168.12.2/500      none/none            READY
      Encr: AES-CBC, keysize: 256, PRF: SHA256, Hash: SHA256, DH Grp:15, Auth sign: PSK, Auth verify: PSK
      Life/Active Time: 86400/879 sec
      CE id: 1001, Session-id: 1
      Status Description: Negotiation done
      Local spi: 40BFB27B5A1863C2       Remote spi: E894779083360034
      Local id: R1.NWL.LAB
      Remote id: R2.NWL.LAB
      Local req msg id:  0              Remote req msg id:  2
      Local next msg id: 0              Remote next msg id: 2
      Local req queued:  0              Remote req queued:  2
      Local window:      5              Remote window:      5
      DPD configured for 0 seconds, retry 0
      Fragmentation not  configured.
      Dynamic Route Update: disabled
      Extended Authentication not configured.
      NAT-T is not detected
      Cisco Trust Security SGT is disabled
      Initiator of SA : No
 IPv6 Crypto IKEv2  SA
Excellent. We have an IKEv2 SA. You can also use this command which gives a similar output:
R1#show crypto ikev2 session detailed
 IPv4 Crypto IKEv2 Session
Session-id:1, Status:UP-ACTIVE, IKE count:1, CHILD count:1
      Life/Active Time: 86400/896 sec
Child sa: local selector  192.168.12.1/0 - 192.168.12.1/65535
          remote selector 192.168.12.2/0 - 192.168.12.2/65535
          ESP spi in/out: 0xF653765B/0xD480A04F
          AH spi in/out: 0x0/0x0
          CPI in/out: 0x0/0x0
          Encr: AES-CBC, keysize: 256, esp_hmac: SHA256
          ah_hmac: None, comp: IPCOMP_NONE, mode tunnel
 IPv6 Crypto IKEv2 Session
When it comes to IKEv2, everything looks good.
IPSec
Let’s dive into IPSec. We’ll check our profile:
  • Full Access to our 777 Lessons. More Lessons Added Every Week!
557 Sign Ups in the last 30 days
satisfaction-guaranteed
100% Satisfaction Guaranteed!
No Questions Asked!
