BGP Prevent Transit AS
By default, BGP will advertise all prefixes to EBGP (External BGP) neighbors. This means that if you are multi-homed (connected to two or more ISPs), you might become a transit AS. Let me show you an example:
R1 two ISPs 3 loopbacks
R1 is connected to ISP1 and ISP2, and each router is in a different AS (Autonomous System). Since R1 is multi-homed, the ISPs may use R1 to reach each other. To prevent this, we’ll have to ensure that R1 only advertises prefixes from its own autonomous system.
As far as I know, there are four methods how you can prevent becoming a transit AS:
  • Filter-list with AS PATH access-list.
  • No-Export Community.
  • Prefix-list Filtering
  • Distribute-list Filtering
Prefix-lists or distribute-lists will work, but it’s not scalable if you have thousands of prefixes in your BGP table. The filter-list and no-export community work very well since you only have to configure them once, and it will not matter if new prefixes show up. First, we’ll configure BGP on each router:
R1(config)#router bgp 1
R1(config-router)#neighbor 192.168.13.3 remote-as 3
ISP1(config)#router bgp 2
ISP1(config-router)#neighbor 192.168.12.1 remote-as 1
ISP2(config)#router bgp 3
ISP2(config-router)#neighbor 192.168.13.1 remote-as 1
The commands above will configure EBGP (External BGP) between R1 – ISP1 and R1 – ISP2. To make sure we have something to look at, I’ll advertise the loopback interfaces in BGP on each router:
R1(config-router)#network 1.1.1.0 mask 255.255.255.0
ISP1(config-router)#network 2.2.2.0 mask 255.255.255.0
ISP2(config-router)#network 3.3.3.0 mask 255.255.255.0
With the networks advertised, let’s take a look at the BGP table of ISP1 and ISP2 to see what they have learned:
ISP1#show ip bgp
BGP table version is 4, local router ID is 11.11.11.11
              r RIB-failure, S Stale
*> 1.1.1.0/24       192.168.12.1             0             0 1 i
*> 2.2.2.0/24       0.0.0.0                  0         32768 i
*> 3.3.3.0/24       192.168.12.1                           0 1 3 i
ISP2#show ip bgp
BGP table version is 4, local router ID is 33.33.33.33
*> 1.1.1.0/24       192.168.13.1             0             0 1 i
*> 2.2.2.0/24       192.168.13.1                           0 1 2 i
*> 3.3.3.0/24       0.0.0.0                  0         32768 i
The ISP routers have learned about each other networks, and they will use R1 as the next hop. We now have everything in place to play with the different filtering techniques.
Filter-list with AS-PATH access-list
Using a filter-list with the AS-PATH access-list is probably the most convenient solution. It will ensure that you will always only advertise prefixes from your own autonomous system. Here’s how to do it:
R1(config)#ip as-path access-list 1 permit ^$
R1(config-router)#neighbor 192.168.12.2 filter-list 1 out
R1(config-router)#neighbor 192.168.13.3 filter-list 1 out
The ^$ regular expression ensures that we will only advertise locally originated prefixes. The ^ is the start of the string and the $ is the end of the string. This means we have an empty string. With BGP, the only time you see a path with no AS-PATH is when you have a route that your router originated or a route from an IBGP neighbor. In other words, a locally originated route.
We’ll have to apply this filter to both ISPs.
Keep in mind that BGP is slow…if you are doing labs, it’s best to speed things up with clear ip bgp *
Let’s verify our configuration:
R1#show ip bgp
BGP table version is 4, local router ID is 22.22.22.22
*> 1.1.1.0/24       0.0.0.0                  0         32768 i
*> 2.2.2.0/24       192.168.12.2             0             0 2 i
*> 3.3.3.0/24       192.168.13.3             0             0 3 i
R1 still knows about the prefixes from the ISP routers. What about ISP1 and ISP2?
ISP1#show ip bgp
BGP table version is 7, local router ID is 11.11.11.11
ISP2#show ip bgp
BGP table version is 7, local router ID is 33.33.33.33
ISP1 and ISP2 only know about the 1.1.1.0 /24 network. Excellent, we are no longer a transit AS!
ISP1
hostname ISP1
interface Loopback 0
 ip address 2.2.2.2 255.255.255.0
interface fastEthernet0/0
router bgp 2
ISP2
hostname ISP2
 ip address 3.3.3.3 255.255.255.0
router bgp 3
R1
hostname R1
interface fastEthernet0/1
router bgp 1
On to the next method…
No-Export Community
Using the no-export community will also work pretty well. We will configure R1 so that prefixes from the ISP routers will be tagged with the no-export community. This ensures that the prefixes from those routers will be known within AS 1 but won’t be advertised to other routers.
R1(config)#route-map NO-EXPORT
R1(config-route-map)#set community no-export
R1(config-router)#neighbor 192.168.12.2 route-map NO-EXPORT in
R1(config-router)#neighbor 192.168.13.3 route-map NO-EXPORT in
I’m only using one router in AS 1, if you have other routers and are running IBGP (Internal BGP) then don’t forget to send communities to those routers with the neighbor <ip> send-community command.
Let’s see what ISP1 and ISP2 think about our configuration:
ISP1#show ip bgp
BGP table version is 11, local router ID is 11.11.11.11
ISP2#show ip bgp
BGP table version is 11, local router ID is 33.33.33.33
They only know about network 1.1.1.0 /24.
ISP1
hostname ISP1
router bgp 2
ISP2
hostname ISP2
router bgp 3
R1
hostname R1
router bgp 1
route-map NO-EXPORT
Onto the next method!
Prefix-List Filtering
Using a prefix-list we can determine what prefixes are advertised to our BGP neighbors. This works fine, but it’s not a good solution to prevent becoming a transit AS. Each time you add new prefixes, you’ll have to reconfigure the prefix-list. Anyway, let me show you how it works:
R1(config)#ip prefix-list NO-TRANSIT permit 1.1.1.0/24
R1(config-router)#neighbor 192.168.12.2 prefix-list NO-TRANSIT out
R1(config-router)#neighbor 192.168.13.3 prefix-list NO-TRANSIT out
The prefix-list above will only advertise 1.1.1.0 /24 to the ISP routers. Let’s verify the configuration:
  • Full Access to our 785 Lessons. More Lessons Added Every Week!
1885 Sign Ups in the last 30 days
satisfaction-guaranteed
100% Satisfaction Guaranteed!
No Questions Asked!
  1. Many thanks for the lesson, it’s very easy to understand!
  2. What about this method, Rene?
    access-list 1 permit 1.1.1.0 0.0.0.255
    route-map NO-EXPORT permit 10
      match ip address 1
    neighbor 192.168.12.2 route-map NO-EXPORT out
    neighbor 192.168.13.3 route-map NO-EXPORT out
    Ofc we can use “match ip address prefix-list” as well. And my deepest respect for all what you do for us all.
  3. An access-list will work as well, no problem at all :slight_smile:
  4. Nice!!! It cleared my questions!!! Thanks a ton!!!
60 more replies! Ask a question or join the discussion by visiting our Community Forum
